Headlight bulb CEL
Old Mar 19, 2007 | 12:47 AM
B5luver's Avatar
Default Headlight bulb CEL
I recently installed HIDs into my B5 and now because the HIDs use less power, my HUD is telling me I have a bulb out, anyway to turn that off???
Old Mar 19, 2007 | 01:33 AM
S_R_N83's Avatar
Default RE: Headlight bulb CEL
Use a 2.2k Ohm resistor and it will get rid of that. Look in the vendors for sale section under the visionbulbs forum, there is a diagram that shows you where to place it there.
Old Mar 19, 2007 | 01:42 AM
B5luver's Avatar
couldn't find the diagram, all i saw in the vision bulbs forum was a convo about someone not getting their product...
Old Mar 20, 2007 | 01:55 AM
S_R_N83's Avatar
[IMG]local://upfiles/8374/254B081A550E42E9B545B1703A483C58.jpg[/IMG]
Old Apr 2, 2007 | 08:08 PM
B5luver's Avatar
Hmm I couldn't get the resistors to work for me, I used one 2.2k ohm resistor per side and still had thewarning go off. Radioshack has two different types of 2.2k ohm resistors, both are 5% tolerance,one is 1/4watt and the other is 1/2watt, neither worked. What should I do now, can you shut off that sensor through VAG-com?
Skins54
Feb 11, 2013 04:01 PM
mxjess
Nov 28, 2008 03:00 PM
CALMANAUDI
Feb 20, 2007 03:48 PM
joelml
Jan 17, 2007 09:22 PM
reneriarik
Dec 1, 2006 12:40 PM
