Headlight problems
Old May 4, 2005 | 02:07 PM
tm2131's Avatar
Default Headlight problems
Hey IM havin a hel of a time tryin to remove he headlights from my 97 a4i cant for the life of me figure it out. I got teh 2 expoed bolts on top out but the lights are stlll pretty secure in teh housing nd i cant find were ese to g or if im guana need any special tools or tricks to remove them. Can NE one Hellp[&:]
Old May 4, 2005 | 02:16 PM
jukeit's Avatar
Default RE: Headlight problems
f i wr u i wld tk a slg hmr 2 the sob.
Old May 4, 2005 | 02:28 PM
konboy22's Avatar
TM... i know this a new model but i dont think it would be that different. Correct me if i am wrong.
Try This
Old May 4, 2005 | 03:28 PM
Jestnomen's Avatar
6th Gear
Remove the two top screws. On the back of the headlight you'll see where the side blinker connects. There is a little bar that pops off, and the turn signal will just slide out. You should see one more screw toward the bottom of the light then.
Old May 4, 2005 | 03:33 PM
Yuikio's Avatar
Yeah, where the turn signal connects to the main headlamp assembly there's a little tab you have to press down on, and then the turn signal comes out, there's a third Torx screw on the side of the main headlamp, and then you're good.
Old May 4, 2005 | 04:09 PM
hb972.8q's Avatar
here are the steps with photos...
this should be the same as yours...hopefully without some minor scraches
[IMG][IMG]
take off two top screws...to the right there is a hole
[/IMG][IMG]
look down the hole you should have a headlight aimer screw and below that you have a clip that holds on the corner light.. bend clip off corner light (is attached to main headlight)
could not focus on it
[/IMG][IMG]
[/IMG][IMG]
after clip is off.... slide out (toursd the front not to the side) blinker light...might be on there good ...this is my clip (yours is slightly differant)
[/IMG][IMG]
here is the 3rd bolt
[/IMG][IMG]
closer pic
[/IMG][/IMG]
after that the main headlight will come right out...dont forget to unplug wire harness from the back of the headlight
sllander85
Feb 13, 2011 01:25 AM
ibdaveisme
Jun 15, 2010 03:18 PM
SSPhotography
Aug 28, 2009 04:14 PM
wgrand802
Jul 14, 2009 01:13 PM
MNA6
Sep 14, 2008 12:57 PM
