headlight switch
Old Aug 24, 2006 | 10:06 PM
guse111's Avatar
Default headlight switch
i have a 96 a4 q does anyone know how to remove the headlight switch or how to access it?
guse
Old Aug 24, 2006 | 10:30 PM
tooxtreme8813's Avatar
Default RE: headlight switch
you have to remove teh steering wheel
Old Aug 26, 2006 | 06:39 PM
dankhound's Avatar
Which isnt as hard as it may seem. You need a t30 torx to remove the 4 bolts that hold on the airbag. The disconnect the wires from the airbag and set it aside face up. Youll need a size 12 tripple square to remove the bolt that holds on the steering wheel. Mark the wheel so that you can put it on in the same place. From there a phillips screwdriver and an allen socket will remove the steering colum trim and youll have full acces to the switch assembly.
Old Jun 4, 2009 | 11:29 AM
supasizefries's Avatar
Any idea where to get this socket attachment?
99A4NOW
Mar 28, 2011 08:51 AM
Kaufman1009
Jun 29, 2010 08:40 PM
Influentialstylez
Mar 29, 2007 04:30 AM
LUVmyA4
Feb 14, 2007 02:11 PM
krisdebo
Jun 18, 2005 08:41 PM
