headlight washer problem
Old May 14, 2005 | 07:28 PM
CBing's Avatar
Default headlight washer problem
Hey guys,
Quick question. Today I noticed that when my headlights are on and I operate my windshield washer,
my headlight washer does not pop up to clean the headlights. Has anyone ever experienced this problem?
And do I have to take it to the dealer or can this be simply fixed.
I understand that the headlight washer system works under water pressure. Any advice
C-bing
Old May 14, 2005 | 07:38 PM
headshok2002's Avatar
Default RE: headlight washer problem
I think the fuse for those things blows frequently, if i'm not mistaken. So check the fuse for it, and go from there...
Old May 14, 2005 | 11:47 PM
Jestnomen's Avatar
6th Gear
May be a bad pump also.
Old May 15, 2005 | 01:12 AM
david9999's Avatar
If both sides don'w pop up, it is probably the fuse or pump, both of which often die. If it is one side, or there is leaking, it is probably the sprayer, which is even more expensive to replace than the pump.
johnstef
Mar 3, 2014 08:41 PM
mcanedo92588
Jul 1, 2013 11:27 PM
SloRide
Feb 24, 2008 02:42 PM
dmelkmo
May 26, 2007 06:54 PM
dezithug
Aug 9, 2006 12:56 PM
