Headlights don't work + airbag light
Old Jul 30, 2007 | 07:17 PM
outasflyguy's Avatar
Default Headlights don't work + airbag light
i tried the headlight switch article DIY http://www.audiworld.com/tech/elec114.shtmlbut this didn't help turn my lights back on... My low beams + fog lights/ rear fog light does not turn on, EVEN on the interior central display.... my highbeams work when i pull towards me but not when i push away... and the corner lights next to the headlights are still working... checked the fuses, they're ok... After the DIY i noticed that my airbag light is on... I know that I put the airbag on properly along with the connector. How do I reset this light? Can I do it with the OBD II? All help is appreciated!!!
Car: 98.5 A4 1.8TQ
Old Jul 30, 2007 | 07:37 PM
tractioncontrol's Avatar
Default RE: Headlights don't work + airbag light
Sounds like a bad headlamp relay, but I work on Toytas so I'm not sure. I would guess that you broke the spiral cable when you did the diy and you won't be able to shut the light off without replacing it (just a guess).
Old Jul 30, 2007 | 08:23 PM
bmr18t's Avatar
i did a hid uprade to my car a few months back and after i got done the air bag light came on. is there some sort of sensor up by the headlights that i may have bumped that would cause the air bag light to come on?
Old Jul 30, 2007 | 09:05 PM
are the relays at in my car right behind the fuses? and which ones would they be for bad headlights?
Old Jul 31, 2007 | 12:51 AM
Anyone know WHERE the headlight/foglight relays are??? what do I use to test them? ive been searching all day on like 5 forums and still cant figure out where it is and which one is the right relay..
Old Jul 31, 2007 | 10:14 PM
anyone know where the headlight relays are??? please any help? I kinda need em' for driving at night...
Old Jul 31, 2007 | 10:24 PM
cacaro's Avatar
i did an hid upgrade on my a4 too, and the air bag light is now on too, after 2 days with hid's. Does anyone know why this is happening???
Old Aug 1, 2007 | 04:45 AM
mark_2328's Avatar
My airbag light came on a little while after i did my t-belt? Any ideas?
Old Aug 1, 2007 | 04:09 PM
Still hoping for an answer from anyone... please before I spend money on a new headlight switch... i wanna know FIRST if it could be the relays... anyone know where the headlight relays are??? Please
Old Aug 1, 2007 | 07:12 PM
cacaro's Avatar
in my passat the headlight relays wher behind the fuse box, if you take the cover off and look past it through one of the openings they might be in their.
