HELP!!!
I just bought an 03 A4 quattro about 3 weeks ago. Last night i parked it on front of a friends house for the night. When i started it this morning, the gas gauge showed i had less fuel then i originally thought i had. it showed i had about 1/4 tank left, and soon after driving it dropped to the 10L mark (the red area).
So i filled up immediately, however i was only able to add around 35 liters (66 liter fuel tank).
Whats the deal? Is my sending unit done?
just for the record, it was parked on a SLIGHT angle towards the passenger side, and the temperature did drop to about freezing point that night (if that helps at all).
Someone enlighten me, please!!!!
Thanks!
Thanks!
Bam_Bam I found this that could possibly help you: https://www.audiforums.com/m_20295/tm.htm it shows you where it is and how to change it.
I'm having a similar problem. I filled up my tank and my gas gauge shows that it is empty. But I remember reading on these forums before if you turn on your car (not engine) that your gas gauge will act like this. Does anyone know how to fix this, I was thinking it was the sender unit, but as I was getting out the car my passenger turned on the car to listen to a CD and I was thinking that caused it. Also how much is a sender and to get it installed if that is the problem?
Thank you
Thank you
