Help...
Old Jul 31, 2007 | 06:04 PM
daesharacor's Avatar
Default Help...
Hey guys-
I have the stock chip in right now, I put it in yesterday. I was driving home from work today when I realized that it was only boosting to exactly 4psi. I've heard of limp mode before, so I did a little research and checked for stored DTC's. There was one stored, a 'throttle actuator servo low voltage'. I thought that was pretty wierd, so I cleared it and went out... still limp. I unplugged the battery for 15 minutes, plugged it back on, went out... still limp. Coincidentally, my windows suddenly stopped doing the one-touch down thing today. Odd, right?
I have heard unplugging the MAF, and checking the n75 valve... any other suggestions?
And another question, if i put the k04 and chip in next week, will it still be a problem?
Thanks.
Old Jul 31, 2007 | 10:07 PM
Default RE: Help...
bump... the n75 connections look fine. Any other way to test if it's still good?
Old Jul 31, 2007 | 11:04 PM
Default RE: Help...
i tested the n75. 23 ohms, and i put 12V to the solenoid and it clicked.
Any other ideas? ... please?
Old Jul 31, 2007 | 11:16 PM
96audia4's Avatar
Default RE: Help...
What was the actual code? Also, the one-touch is normal to stop working after disconnecting the battery, it has to re-learn the feature.
Old Jul 31, 2007 | 11:17 PM
acetrebo's Avatar
Default RE: Help...
None of us can answer.
Soon as we look at your sig, we become speechless and can no longer concentrate.
Old Jul 31, 2007 | 11:20 PM
cletusdafetus's Avatar
Default RE: Help...
i thought a4 didnt have limp mode till 99 or 2000
i may be wrong
Old Jul 31, 2007 | 11:25 PM
96audia4's Avatar
Default RE: Help...
ORIGINAL: cletusdafetus
i may be wrong
I was under the same impression because AEB is nDBW, but I've heard that it does have something to limit boost, maybe the N75. I'm pretty sure that he is not in limp mode though, because disconnecting the battery should have cleared that.
Old Jul 31, 2007 | 11:26 PM
Default RE: Help...
i wouldnt put the ko4 in till you get this fixed though
Old Jul 31, 2007 | 11:32 PM
Default RE: Help...
thanks for the responses.
i agree, i can't put the k04 in til i fix this problem
if it throws the code again tomorrow, i'll post it up. meantime, it's not the n75 valve solenoid, so am i correct in assuming that it's either one of three things...
1) not enough voltage to the n75 due to a faulty wire
2) stuck wastegate
3) boost leak
It shouldnt be a coil or icm thing, cause i haven't gotten any misfire codes, right? and i'm pretty sure it's not the maf, because i get a pretty reasonable reading off it from my palm software.
Anybody have any other advice? it's greatly appreciated
Old Jul 31, 2007 | 11:47 PM
96audia4's Avatar
Default RE: Help...
I would concentrate on the code first. I think that is what's causing your problem. Just a guess, but was it 18533 P2101 or 16506 P0122?
