HELP!
Old Oct 3, 2007 | 03:09 PM
Darknight101's Avatar
Default HELP!
Ok I'm at work went out for lunch everything was fine. I get back in right after grabing a sub to come back and eat here and all the sudden there is a Huge rattle massive vibration's and a horrid clutch fell when I get into the parking lot at work. I stop let the car cool down for a min to see if I can hear the rattle. Its there,no CEL just nasty felling vibration. When in nutural and clutch down it is almost unbarable to handel the sound and vibration. I relly cant afford to fix it and still have 6 grand to pay on it atm with no other mode of transportation at my disposible. There is also a nasty vacume leak now that wasnt there yeasterday. It sounds like valves on older cars that little clacking sound you get when there old and you hit the gas. What could it be the lack of a CEL is relly freaking me out I dont want to get a loan out to fix this but if need be I'll have to.
Old Oct 3, 2007 | 03:13 PM
audi_n00b's Avatar
Default RE: HELP!
Can you spell check? That was painful to read.
Old Oct 3, 2007 | 03:14 PM
hiwords's Avatar
Default RE: HELP!
check ur timing belt, vaccum lines (cheap), and the air control valve on ur throttle body.
Old Oct 3, 2007 | 03:21 PM
techbod's Avatar
Default RE: HELP!
it sounds serious as if the engine crank shaft internal problem but could be anything like that even a stuck starter motor could do that so more investigations required
Old Oct 3, 2007 | 03:32 PM
akielb's Avatar
Default RE: HELP!
Check the codes - not all codes will through a CEL
