HELP A4 power problem, including vag-com faults
Hello Audifans,
My car (audi A4 2002) won't start any more. Something is taking the energie out of my battery.
With vag-com i have read the faults. A local dealer (not audi) could not find the problem.
The fault codes are:
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 909 557 J
Component: 2.0L R4/5VS 0001
Coding: 0011581
Shop #: WSC 63351
2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 008 - Implausible Signal - Intermittent
Readiness: 0010 0001
Address 02 -------------------------------------------------------
Controller: 01J 927 156 CR
Component: V30 01J 2.0l 5V RdW 2011
Coding: 00001
Shop #: WSC 63351
3 Faults Found:
18195 - Back-Up Lamp Signal: Short to Ground
P1787 - 35-10 - - - Intermittent
18194 - Back-Up Lamp Signal: Open Circuit
P1786 - 35-10 - - - Intermittent
18132 - Starter Interlock Signal: Short to Ground
P1724 - 35-00 - -
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04279
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
7 Faults Found:
01809 - Actuating Motor for Temperature Flap: Left (V158)
41-10 - Blocked or No Voltage - Intermittent
01810 - Actuating Motor for Temperature Flap: Right (V159)
01274 - Air Flow Flap Positioning Motor (V71)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
00819 - High Pressure Sensor (G65)
07-10 - Signal to Low - Intermittent
01794 - Control Module Incorrect Chassis (VIN) Number
35-00 - -
Any ideas experts??
[IMG]local://upfiles/11142/1ABC81FEF3E94AC29230D67B6B9EAF86.jpg[/IMG]
[IMG]local://upfiles/11142/D8EBEB24B28A481EA5AA6F588404B8DD.jpg[/IMG]
Coding: 0011581
Shop #: WSC 63351
2 Faults Found:
Coding: 00001
Shop #: WSC 63351
3 Faults Found:
P1724 - 35-00 - -
Coding: 04279
Shop #: WSC 06435
1 Fault Found:
Coding: 00000
Shop #: WSC 63351
7 Faults Found:
35-00 - -
Any ideas experts??
Did you have them clear the codes? Best way to start addressing the problems is to clear them and see if they come back. Sometimes a disconnected battery/performance chip/component replacement can cause some of those codes. If you have had you car worked on sometimes fault codes appear and need to be cleared. Otherwise, thats a lot of codes you got. Multiple codes can be caused by one thing so dont get too worried. I dont know about what could be draining your battery, could be a bad battery? If it was the alternator Im sure there would be a code for that, maybe there is but I cant identify it... Try typing in the fault codes in any search engine and see what results you get. Thats what I did. Have you had AC maintnance done? Replaced your battery in the last 5 years?
ORIGINAL: jackychany
thanks for the good suggestions. I will clear the codes tomorrow to see how things run after ..
but how can i clear it with vag-com 311-n??
Then right after you scan for codes, you'll see a button that says "Clear Faults" [or something like that]. Just click that button and you're good to go. Rescan later to see if they come back.
Edit: Oops he beat me to it ^^^^^
ORIGINAL: drkenan
