HELP!! Anyone with Vision HID conversion kit
Old Jan 23, 2007 | 09:30 PM
Bip's Avatar
Bip
Default HELP!! Anyone with Vision HID conversion kit
Hey all,
I got my kit today and Iwent under the hood looking for places to mount the ballasts. I thinkI have a spot on the right side of the engine bay but I cannot get one on the left(side with the airbox). I was wondering if anyone has pics of an install that they did...where did you mount the ballasts/ is the relay long enough to reach the battery?
Any help would be appritiated.
Thanks in advance
Old Jan 23, 2007 | 11:53 PM
S_R_N83's Avatar
Default RE: HELP!! Anyone with Vision HID conversion kit
I mounted the ballasts under the headlights. They don't seem like they'll fit, but they actually do. I didnt use the relay because I didnt want the light out warning to come up, so I used resistors on both stock harnesses. I was under the impression that since visionbulbs relay only connects to one stock harness that you will get the bulbout warning if you do it that way.
Old Jan 24, 2007 | 12:24 AM
Bip's Avatar
Bip
The vision ballast fits under the headlight?? it didnt seem like it did. How did you put together the resistors?
Old Jan 24, 2007 | 04:17 PM
Bip's Avatar
Bip
bump
Old Jan 24, 2007 | 05:26 PM
S_R_N83's Avatar
ORIGINAL: Bip
Yes it does. It doesn't fit IN the little box area ON the headlight housing, but it does fit under the housing itself if you place it right, believe me.
I believe in the visionbulbs thread in the vendors section, it shows how to put the resistors in..its really easy, you just squeeze it in.
Old Jan 24, 2007 | 07:18 PM
Bip's Avatar
Bip
ok thanks alot ill check it out.I plan on installing on saturday if it is not 5 degreese out.. its supposed to be colllld.
zelda80
Apr 19, 2015 05:52 PM
socaljoe
Jan 11, 2007 03:49 PM
socaljoe
Dec 23, 2006 04:52 AM
SurferForever
Dec 4, 2006 01:03 PM
