Help with BOV... Update!
Old Jun 8, 2006 | 08:30 PM
afasta4's Avatar
Default RE: Help with BOV...
Ok well I think I will get rid of it and either put in the Forge 007 DV or Hyperboost HX. Everything in the car as of now is what came with it when I bought it. I am cerious as to what is bad about Wetterauer?
Old Jun 8, 2006 | 08:36 PM
onepoint8tee's Avatar
I was just kiddin about the "are you ok with that?" thing.. Sort of.. Before I got chipped, when I was researching them, I came accross some people who had bad experiences with that chip on audiworld.com and audizine.com. I honestly cant remember specifics, but i think some people were having limp/closed loop mode problems with it, and some fault codes. But then some people have those same experiences with giac and apr... If you had problems with it, im sure we'd be hearing about them. So rock on with your bad *** chip!!! Shoulda got giac's k04 file though, its way more aggressive i think...
Old Jun 8, 2006 | 08:39 PM
04a4's Avatar
i run a forge DV at 22psi with my K04 no problem
Old Jun 9, 2006 | 01:41 AM
16w/A4's Avatar
what kind of boost can you get out of a KO4
Old Jun 9, 2006 | 11:14 AM
north5995's Avatar
like 22 or so. But more boost does not necessarily = more HP/TQ
Old Jun 9, 2006 | 05:19 PM
Beer Mod's Avatar
ORIGINAL: north5995
Good point! I think alot of people overlook that fact...
Old Jun 14, 2006 | 05:24 PM
afasta4's Avatar
Default RE: Help with BOV... Update!
One more question about this. What kind of DV will be a direct fit replacement for the BOV or what kind of changes will I need to make?
Thanks
Old Jun 14, 2006 | 05:51 PM
  #18
north5995's Avatar
Your DV won't go into the same spot as your BOV. They are in totally different spots. Your DV will be under your car in front of the passenger wheel. If you do a search you can find a diagram explaining how the DV hoses go and what exactly it is hooked up to.
Old Jun 14, 2006 | 06:16 PM
  #19
a4bsix's Avatar
just recirculate it with a hks kit, itsl ike $40-50, that guy already put a flange and welded it on, dont waste too much money on that crap
Old Jun 15, 2006 | 05:45 PM
  #20
afasta4's Avatar
Looks like I found what I was looking for.
http://www.hksusa.com/products/?id=798
Once I get in all hooked up Ill let you guys know how well it worked.
Thanks for the help
Kevin
Jul 31, 2012 03:41 PM
NickBroderick
Feb 7, 2010 01:07 PM
pitt
Dec 2, 2009 10:03 AM
bbbobbb
Jan 21, 2008 12:10 AM
