help, car is shivering
Old Feb 19, 2005 | 06:52 PM
rustyo's Avatar
Default help, car is shivering
i just purchased a used A4 1.8T quattro. Car has about 36,000 miles on it. The car seems to tremble, moderately but noticeably, in nuetral when cold. (Its not a vacuum hose, I just replaced it.) Car quiets down (tho not completely) after it has warmed up a bit. I'd be grateful if anyone had any suggestions about what might be causing the shakes. Thanks.
Old Feb 19, 2005 | 07:06 PM
Jestnomen's Avatar
6th Gear
Default RE: help, car is shivering
does the car ever feel like it is going to stall?
Old Feb 19, 2005 | 07:12 PM
rustyo's Avatar
no. the exhaust seems to sputter rapidly at first, and the steering wheel trembles (because the car is trembling). That's all I notice. After about ten mins of driving it settles down a bit, tho not completely.
Old Feb 20, 2005 | 12:33 AM
david9999's Avatar
Sounds like a job for VAGCOM.
Look for codes (eg misfire cyl 2).
When was the last throttle body adjustment? When was the last time the spark plugs were changed?
Old Feb 20, 2005 | 02:48 AM
rustyo's Avatar
I bought the car used from an audi dealer a month or so ago. It is a certified used car, so I assume things were changed when hey shd have been. I suppose I may be giving them too much credit tho. What's VAGCOM?
Old Feb 20, 2005 | 02:55 AM
Jestnomen's Avatar
6th Gear
vag com is a diagnostic cable used to scan the computer modules in the car for fault codes. Highly recommended if you play on doing any of your own maintanance.
---->> Ross-tech.com
Old Feb 20, 2005 | 08:46 AM
david9999's Avatar
Ummmm, if you bought your car certified from an Audi dealer, it probably has an extended warranty of some sort.
Take it back to them for them to find out what the problem is and fix it. Afterall that is why you bought the car certified.
Old Feb 20, 2005 | 12:32 PM
rustyo's Avatar
I will. I had asked because the car just last week came back from service. They had insatalled a new vacuum hose. So I thought they would have caught whatever this is as well. I'm just trying to educate myself a bit on the problem before I go back there. I didn't know if what I'm seeing is a common problem or not. Anyway, I guess I'll go back and see what they say. Thanks.
Old Feb 20, 2005 | 12:54 PM
david9999's Avatar
Could be they missed a connection, could be engine missfire, or could be just the roughness of a 4 cyl v a 6 cyl.
I guess could also be an issue with engine mounts, but car is pretty young.
