HELP! did i just destroy my a engine? F****
Old Sep 3, 2006 | 08:05 PM
Karl's Avatar
Default RE: HELP! did i just destroy my a engine? F****
if vise grips dont seem to grab it.. then grab a small grinder and grind two sides.. makeing it so that a wrench could fit on it.. then take it out that way.. just be careful with the metal shavings if you take this route
Old Sep 3, 2006 | 08:41 PM
gregp1962's Avatar
This is definatly not a crisis. See this thread for a real CRISIS! https://www.audiforums.com/m_343566/tm.htm
Regarding your bolt problem.... If the bolt is screwed in, remove it using the procedure in reply 9, above. If it's pressed in rather than screwed, cut it off, drill it out and retap threads in the hole. It's easier than it sounds. BE CAREFUL OF METAL SHAVINGS!!
curtmon03
Mar 19, 2012 08:35 PM
curtmon03
Oct 4, 2011 07:49 PM
