Help : Front End Acting Crazy
Old Dec 1, 2005 | 11:04 PM
Heinzanova's Avatar
Default Help : Front End Acting Crazy
My 98 2.8 Avant recently developed a problem that seems to be worsening.
The steering has a shake in it, and up till recently it was only noticable in the wheel, not to passengers in the car. The problem makes no noise, and seems to disapear when turning to the right. The shaking is getting worse in the wheel and to the point now where the whole car shakes even at low speeds. WTF
I checked Air Pressure
I tightened all the lugs to make sure
I had a third party drive the car and they described it as an almost side to side pulling, although I don't feel this is accurate.
According to audi they said all the recalls have been done on this car with-in the past 10,000 miles.
Next suggestions?
Old Dec 1, 2005 | 11:13 PM
AudiTech04's Avatar
Default RE: Help : Front End Acting Crazy
Tire balance problem most likley
Could be a bent rim (i see a lot of that)
Bad tire possibly
Old Dec 2, 2005 | 12:00 AM
Quartz05's Avatar
I'll be the first to admit that I suck at European suspensions but on all my old muscle cars a worn tie rod end would make the car do just what you're describing.
Old Dec 2, 2005 | 03:05 AM
Yuikio's Avatar
Could definitely be a TRE. Those are what connect the steering rack to the suspension, so definitely check those out. They're cheap.
Old Dec 2, 2005 | 03:08 PM
Heinzanova's Avatar
It was the passenger side front tire.
Turns out from alot of driving in NYC with it, I have snapped a steal belt in the tire, the inner and outter belts seperated and the inner one snapped. Causing the tire when on a lift to look like this
\----:____:/
Causing the wheel to push right, but the car wanting to go strait.
Luckly the tread ware was good enough on the rear two that I only had to replace the front to. Car is like new again :-D
Still $250 but still better than $x,xxx
Old Dec 2, 2005 | 03:11 PM
Slowb5's Avatar
ORIGINAL: Heinzanova
\----:____:/
word.
dfux86
Apr 2, 2013 03:21 PM
uscgjoe79
Oct 22, 2012 01:38 PM
ben_a4quattro
Feb 19, 2012 12:57 PM
myaudi98
Jun 15, 2006 05:51 PM
Novablue454
Sep 26, 2005 03:30 AM
