Help with GTRS
Old May 23, 2007 | 12:01 AM
gotaudi's Avatar
Default Help with GTRS
Today I found out that the unitronics tune for a 2001 uses a 4 bar FPR (I was using a 3 bar) so I thought this would fix my problems with my car but it did not.... my fuel trims are still thought the roof (I even reset them today after I put in the FPR and the part throttle is at +22.4%) this car is not liking the BT
I need some serious help....
here are some logs that I took today....
boost 19~20 PSI, 70 degrees out on 91 octane.... with 4 Bar FPR, fixed a few vac leaks and still my car sucks....
A/F Ratio
http://www.mediafire.com/?7gnxm4cvd1g
group 2 and 3
http://www.mediafire.com/?9f0tshmz1me
timing corrections
http://www.mediafire.com/?5m1udnxnwmm
Old May 23, 2007 | 02:09 AM
00A41.8Quattro's Avatar
Default RE: Help with GTRS
Sounds like ur not getting enough air and/or enough spark. Check the plugs, one of them might be fouled out.
Old May 23, 2007 | 02:10 AM
gotaudi's Avatar
I changed the plugs about 100 miles ago
Old May 23, 2007 | 02:14 AM
BadLuckAudi's Avatar
what injectors are you running and are they clean
Old May 23, 2007 | 02:22 AM
gotaudi's Avatar
I am running bosch 440cc Green giants (not the greentops) @ 4bar (about 510cc/min) and they are brand new with about 400miles on them. I had the same problem with the greentops that is why i switched them out... the only thing i got out of them was a smooth Idle....
Old May 23, 2007 | 02:23 AM
maybe your map sensor is screwy
Old May 23, 2007 | 02:29 AM
gotaudi's Avatar
How bad could a faaulty Map sensor make the car run???
Old May 23, 2007 | 03:19 AM
I dunno lol it was justa guess but even at that my guess it is could mess with things a bit i dont know how much though what MAF are you running and is it clean
Old May 23, 2007 | 03:31 AM
gotaudi's Avatar
The MAF sensor is brand new... well 3 days old... so I do not think the MAF seensor is dieing. But what is weird is I am getting a low MAF readings
Old May 23, 2007 | 07:40 AM
dafrazi's Avatar
Can you post a log of blocks 32 & 33 so that we can see the fuel trim?
