Help with GTRS
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
Today I found out that the unitronics tune for a 2001 uses a 4 bar FPR (I was using a 3 bar) so I thought this would fix my problems with my car but it did not.... my fuel trims are still thought the roof (I even reset them today after I put in the FPR and the part throttle is at +22.4%) this car is not liking the BT
I need some serious help....
here are some logs that I took today....
boost 19~20 PSI, 70 degrees out on 91 octane.... with 4 Bar FPR, fixed a few vac leaks and still my car sucks....
A/F Ratio
http://www.mediafire.com/?7gnxm4cvd1g
group 2 and 3
http://www.mediafire.com/?9f0tshmz1me
timing corrections
http://www.mediafire.com/?5m1udnxnwmm
A/F Ratio
group 2 and 3
timing corrections
I am running bosch 440cc Green giants (not the greentops) @ 4bar (about 510cc/min) and they are brand new with about 400miles on them. I had the same problem with the greentops that is why i switched them out... the only thing i got out of them was a smooth Idle....
