Help with headlights
I have a A4 1996 and when i turn my head light on everything comes on except my headlight. I can flash my high beams but my headlights done come on. I think it maybe be a headlight relay but i am not sure. If someone shed some light on what is going on ir how i can fix this.
Thank you
Thank you
it would be odd like that for both headlights to go out...have your headlights ever worked?....if they just "went out" its probably in the wiring because as headlights "go out" they get dimmer and dimmer
Do you know english? The relay that controls the hi beams and low beams are the same one so the relay is out. Take the hi beam out and plug it into the low beam and see if it works (if both of them are halogen)
Do you have zenon lights? Do you know what that is?
I will try switching the high bream with the low breams but i dont know if i have zenon lights
ORIGINAL: auditech79
ORIGINAL: cnova
Yes both headlight did work and just went out. But the parking lights work and the truning lights work. It crazy just the hreadlight dont.
