Help with headlights
Old Oct 17, 2007 | 08:47 PM
cnova's Avatar
Default Help with headlights
I have a A4 1996 and when i turn my head light on everything comes on except my headlight. I can flash my high beams but my headlights done come on. I think it maybe be a headlight relay but i am not sure. If someone shed some light on what is going on ir how i can fix this.
Thank you
Old Oct 17, 2007 | 08:51 PM
hiwords's Avatar
Default RE: Help with headlights
check to see if u have power going to them. did u check the bulb?
Old Oct 17, 2007 | 08:54 PM
cnova's Avatar
I will check to see if i there is power to them but i think they have power if the high beams work. i will check the bulbs thank you.
Old Oct 17, 2007 | 08:57 PM
AudiBama's Avatar
it would be odd like that for both headlights to go out...have your headlights ever worked?....if they just "went out" its probably in the wiring because as headlights "go out" they get dimmer and dimmer
Old Oct 17, 2007 | 09:07 PM
auditech79's Avatar
Do you know english? The relay that controls the hi beams and low beams are the same one so the relay is out. Take the hi beam out and plug it into the low beam and see if it works (if both of them are halogen)
Do you have zenon lights? Do you know what that is?
cnova's Avatar
Yes both headlight did work and just went out. But the parking lights work and the truning lights work. It crazy just the hreadlight dont.
Old Oct 17, 2007 | 09:23 PM
cnova's Avatar
I will try switching the high bream with the low breams but i dont know if i have zenon lights
ORIGINAL: auditech79
Old Oct 17, 2007 | 09:26 PM
auditech79's Avatar
Zenons are different from the hi beams, and are generally blue in color when you first turn them on and much much brighter.
Old Oct 17, 2007 | 09:29 PM
AudiBama's Avatar
ORIGINAL: cnova
cnova's Avatar
My headlights have the foglights built in tothe headlight casing.
