Help Identify Part -- new help with code now
Old Jul 1, 2007 | 01:14 AM
Mankind121's Avatar
Default Help Identify Part -- new help with code now
I think this is a vacuum valve, but I need the part number if anyone can help. I'll post the pics of the location, its above the air filter.
It's a 99 A4 Quattro Turbo 1.8
Thanks
(my hand isn't casper white, I added brightness to the picture)
[IMG]local://upfiles/37811/C50AF70CE1D64F34AC7F2D7244E58729.jpg[/IMG]
Old Jul 1, 2007 | 01:16 AM
Mankind121's Avatar
Default RE: Help Identify Part
now picture of location, above air filter
[IMG]local://upfiles/37811/33084E1AB05B4B09A7A2E367233352C7.jpg[/IMG]
Old Jul 1, 2007 | 02:08 AM
auditech79's Avatar
Your pointing to the location of the N80 Valve for the evap system. Did that check valve have a cover over it?
Old Jul 1, 2007 | 02:29 AM
Mankind121's Avatar
yeah there was a cover, but this thing looks like it melted
i found the part number, the 058 valve, do you know of any good places to buy them?
Old Jul 1, 2007 | 02:34 AM
auditech79's Avatar
Why are you replacing it? Is it leaking? Actually i have an idea if its the N80 valve and you dis-connect the lines going to it you won't hear anything, if its a vaccum check valve and you dis-connect the lines you'll hear a vaccum leak. If its a vaccum leak you can use any part number for replacing the check valve, they are all the same. One way in, one way out.
Old Jul 1, 2007 | 02:37 AM
Mankind121's Avatar
the whole valve is compromised,it looks melted and you can see the red rubber valve stop
Old Jul 1, 2007 | 02:38 AM
Mankind121's Avatar
I saw this today when my car started idling super rough and the check engine light came on, so I'm hoping this is the cause
Old Jul 1, 2007 | 02:40 AM
auditech79's Avatar
Then you should hear a vaccum leak, if nothing its the N80 valve like i said. You have to go to the dealer for this part as far as i know. Not that expensive.
Old Jul 1, 2007 | 02:43 AM
Mankind121's Avatar
thanks for your help, i hope this is causing my problem, this thing looks like its been through war
Old Jul 1, 2007 | 02:45 AM
auditech79's Avatar
What kind of problem are you experiencing?
