Help/Input/Advice on CLutch for 1999 A4 1.8T
Car has 225k km on it and as far as i know original clutch. Just had the timing belt and tensioner etc all completed and had a chip done as well (#16 psi?). Car runs great but seems to get some hesitation under load in 3rd gear at high rpms not sure if its knocking.
ANyhow I want to upgrade the clutch and want to know anythign and everything about my options. WHat have you upgraded to? ANy popular combinations? best prices for setups etc? SHould I upgrade the flywheel and clutch with oem or go aftermarket for each or both?
I heard it uses a dual mass flywheel. If this is true are there any drawbacks to going with a singlemass? My buddy with a vette says his dual mass conversion to single mass makes the tranny rattle like a **** but he saved over 40 lbs.
ANy info /input is appreciated
Edit/Delete Message
Edit/Delete Message
