help installing HID kit from vision bulbs
Old Jul 14, 2007 | 11:36 PM
less_of_me's Avatar
Default help installing HID kit from vision bulbs
I am stuck on step 5....the headlight harness connection. My kit came with the two metal spade connectors and I am not getting the part where the instructions say "you can slide the rongs into the female slot, or simply plice the wires and attach them together". What headlight harness am I supposed to be plugging these into?
I have a 98.5, but I bought the xenon ready one piece ecodes from ecstuning. I also bought the wiring harness to adapt the plugs. It is the D2S kit.
All the other lights work...except for the most important ones...the xenon ones. The high beams work, the blinkers work and when I turn on the headlights, all I get is a solid orange side light.
please help.
Old Jul 14, 2007 | 11:49 PM
96audia4's Avatar
Default RE: help installing HID kit from vision bulbs
You need to connect one of the original low beam wires to the harness so it knows when the low beams are on (I'm guessing thats step five, I threw out my instructions a long time ago)
Old Jul 14, 2007 | 11:54 PM
less_of_me's Avatar
ok....so let's say the low beam wire was the "orange wire". I should splice into the orange wire with BOTH fo the metal spades and connect them just like that?
Thanks for your help so far man...
Old Jul 15, 2007 | 12:25 AM
96audia4's Avatar
ok, I just dug up some instructions. So far, we've established that you need to connect the low beam wire to the relay harness. On mine, I forget which color the low beam wire was (either white black or yellow, i think). Also, it should just plug right into the spade connector on the harness (which was a teal-ish color on mine).
Old Jul 15, 2007 | 12:37 AM
96audia4's Avatar
Here is a pic of the connector. Its actually a brown/yellow set that gets plugged in.
[IMG]local://upfiles/18457/9164CE081C5E4A729DF17B9EE1C4E96D.jpg[/IMG]
Old Jul 15, 2007 | 02:22 AM
less_of_me's Avatar
Thanks for the help. It was the white to the brown yellow and the black to the brown
A4blackedout
Apr 11, 2007 01:18 PM
socaljoe
Jan 11, 2007 03:49 PM
socaljoe
Dec 23, 2006 04:52 AM
SurferForever
Dec 4, 2006 01:03 PM
