Help - Limp mode - Chip problem
Old Dec 10, 2007 | 09:08 AM
drs305's Avatar
Member
Default Help - Limp mode - Chip problem
Since I installed my boost gauge I found my cars GIAC chip is not working properly. I am running about 6lbs or boost when it should be much higher. I called my local GIAC dealer and they said it sounds like my car is in limp mode. They are charging $42 to scan my cars ecu for errors. I know there can be a lot of things that trigger this mode but,does anyone have any idea what some common ones might be?
2001 A4 MAN FWD
Old Dec 10, 2007 | 10:20 AM
The Bishop's Avatar
Default RE: Help - Limp mode - Chip problem
Check all of your fuses, it might be your ecu fuse.
Old Dec 10, 2007 | 10:55 AM
The Russian's Avatar
my car wen into limp mode last week because the Mass Air Flow/Waste Gate valve/and some other intake component fuse went out (they are all connected to one), so yeah check your fuses, the only thing is, limp mode is usually around 3 or 4 psi
Old Dec 10, 2007 | 11:14 AM
drs305's Avatar
Member
I don't have a check engine light on either.... Maybe the N75 is bad? I checked the fuse box and didn't see any bad fuses.
Staudi911
Jan 15, 2015 03:20 PM
Roderick
Sep 5, 2010 08:11 AM
bottlecap
Nov 27, 2009 05:40 PM
jzstuggie
Sep 7, 2009 11:41 AM
djjay
Apr 20, 2007 02:17 PM
