Help me out...
Old May 31, 2007 | 03:29 PM
S_R_N83's Avatar
Default Help me out...
Does anyone know for sure if b5 a4avant oem sports suspension will work fine on a b5 a4sedan. I seach and find different opinions but does anyone know for sure?? Thanks
Old May 31, 2007 | 03:46 PM
akielb's Avatar
Default RE: Help me out...
no it won't - yes it will fit....but won't look right - that the reason they have different part #'s
Old May 31, 2007 | 04:04 PM
2k S4's Avatar
Yes, it will fit, & yes it will work.
However, the rear spring rates are much higher, so the back will sit higher, & the car will understeer even more then stock.
Old May 31, 2007 | 04:10 PM
CRAZYHAWK's Avatar
Stiffer rear springs should increase oversteer.
Old May 31, 2007 | 04:37 PM
2k S4's Avatar
ORIGINAL: CRAZYHAWK
Sorry, you got it backwards... but I had to look it up to make sure, I wasn't backwards...
Understeer causes the car to go straighter than the trajectory that the driver is trying to take. This is sometimes known as pushing, plowing, or ‘refusing to turn in’. However, the car will be fairly stable as it is not wanting to spin. Understeer can appear under heavy acceleration and through heavy braking. If the brake balance is too heavy at the front (the front brakes are stronger than the rear), the car may understeer because the front wheels lock and lose effective steering. To counter understeer, more rear wing can be added to create more downforce at the back of the car, and the rear suspension softened.
The softer wheel rate will give more grip, so if the back is stiffer, it will slip more, creating more understeer.
Old May 31, 2007 | 05:36 PM
S_R_N83's Avatar
thanks guys
Old Jun 1, 2007 | 10:11 AM
CRAZYHAWK's Avatar
ORIGINAL: 2k S4
ORIGINAL: CRAZYHAWK
The last sentence should end "creating more oversteer".
Old Jun 1, 2007 | 12:33 PM
2k S4's Avatar
ORIGINAL: CRAZYHAWK
ORIGINAL: 2k S4
The softer wheel rate (in the front) will give more grip, so if the back is stiffer, it will slip more, creating more understeer.
Sorry, in the front suspension....
