Help me spend $1200
Old Feb 4, 2008 | 02:41 PM
cincyTT's Avatar
I'm make believe
Default RE: Help me spend $1200
mods? psi?
Old Feb 4, 2008 | 02:42 PM
A4speed's Avatar
wow are those apr results typical for an awd too or just fwd?? im gettin a new chip(fvck speedtuning) and i wanna go with the one that has the best prooven results, my tuner is trying to get me to go with unitronics, anyone else go with them? any feedback on that chip at all?? sorry to thread jack btw.
not to many people on here have a Unitronic chip on here. Unitronic is awesome for BT files. They are a very reputable company, I'm just not quite sure how they compare to GIAC and APR.
Old Feb 4, 2008 | 02:47 PM
chaos92287's Avatar
ORIGINAL: cincyTT
mods? psi?
just listed them. forgot the psi. the first dyno was done at 17psi, the others at 20-22
Old Feb 4, 2008 | 02:54 PM
01afour's Avatar
so you guys think unitronics is good if i plan on going bt in the future? is it a stand alone unit or just a solder on chip?
cincyTT's Avatar
I'm make believe
They all seem normal for 20-22psi. I would just get a stg1 and a mbc. Up the boost and then have someone with a vagcom cable bump the timing another 2-3*. Then i can spend the injector money towards an exhaust of vagcom for myself.
Old Feb 4, 2008 | 02:56 PM
01afour's Avatar
hmm...i thought mbc's arent that good to use on our cars, but with a chip is it better cause you can up the fuel?
chaos92287's Avatar
ORIGINAL: 01afour
definitely. and its just a solder on chip
Old Feb 4, 2008 | 03:00 PM
  #18
cincyTT's Avatar
I'm make believe
ORIGINAL: 01afour
with a chip, a mbc changes how the turbo reacts. It makes it spool better, hold boost longer, and lets you set the psi. MBC are a great addition, its people that do it wrong that make others think they are bad. With a kkk turbo, you need a bleed style mbc. This will smooth out the boost and make going into boost nicer
Old Feb 4, 2008 | 03:01 PM
  #19
01afour's Avatar
really!? now i gotta research another chip haha. mabye ill end up going with that one, are the prices around the same as a GIAC/REVO/APR chip? ive never heard of this brand before, so i dont wanna end up wasting another few hundred for a b.s. chip again, even though with this one ill be able to knock on someones door when **** goes wrong haha.
  #20
cincyTT's Avatar
I'm make believe
ORIGINAL: chaos92287
ORIGINAL: 01afour
he has an 01, it will be just a flash.
