Help Needed! - no boost after fixing boost leak
Old Feb 8, 2007 | 02:08 AM
truckjunky87's Avatar
Default Help Needed! - no boost after fixing boost leak
I haven't been getting any boost for about a week or so now- no I don't have a boost gauge but its was obvious nothing was going on. I built myself a boost leak checker and found a loose wastegate line and a crack in the hard elbow to the bypass valve hose. Fixed those and the system held pressure so I took her on the road --- nothing at first. I ran some hard pulls in 2nd & 3rd but didn't feel anything. Suddenly, in the middle of one runi t was like the boost just ripped in for about a second along with a strange sound and then cut off again. It did this one more time and that was it - no more boost.
What gives???
Also, ran it for like 15 minutes trying to get things figured out and when I was done I popped the hood and the turbo was glowing - Is that normal?
Old Feb 8, 2007 | 02:16 AM
tractioncontrol's Avatar
Default RE: Help Needed! - Bo boost after fixing boost leak
The turbo is shot I would guess and because it's not spinning extra heat buildup is happening atthe hot side.
Old Feb 8, 2007 | 05:30 AM
18T's Avatar
18T
If you were pushing the car the turbo will always start to glow, no matter if its shot or not.
Second, check all hoses and connections. Check the L breether valve between the engine and the coolant tank.. those rip all the times.. its a rubber hose in the shape of a L but upside down. check all your vacuum lines.
is your turbo making any funny noises? also is there white smoke coming out of ur exaust?
Old Feb 8, 2007 | 07:03 AM
BadLuckAudi's Avatar
may be a bad DV I doubt the turbo is shot they ALWAYS glow
Old Feb 8, 2007 | 12:33 PM
I'll do another boost leak check and visually look at the hoses. What does the L breather valve connect too? Is ithard or soft? I haven't noticed any white smoke but I'll look and the two instances when the boost kicked in for a second I did hear a strange noise. The noise is what has me worried. Up to this point I haven't had any problems with it.
to4xxx
Jun 8, 2012 11:56 AM
onepoint8tee
Jun 27, 2007 04:38 PM
fenderstrat1184
Dec 21, 2006 02:35 AM
d5coupe
Jul 18, 2006 05:24 PM
a4bsix
Jul 6, 2006 04:28 PM
