HELP!!!!! Noise in the engine
Old Feb 13, 2007 | 01:57 AM
gotaudi's Avatar
Default HELP!!!!! Noise in the engine
okay guys I have a 2001 A4 1.8T and about 2 days ago a faint squeel/chirp has occured in my engine bay, it only happens when you give a little blurp of the gas(quick on and off). you can hear it inside the cabin but when you open the hood you cant hear anything.
I changed my timing belt about two months ago and all the belts are tight. what do you guys think it might be????if you guys could give me some ideas of where to look that would be great.
thank you
Old Feb 13, 2007 | 02:00 AM
onepoint8tee's Avatar
Default RE: HELP!!!!! Noise in the engine
if its ONLY when you "blurp" on/off gas real quick, that sounds like the normal sound of your dv. What DV do you have anyway? I dont see it listed in your mod list.. If you have the stock dv then its probably dying/dead/demolished.
Old Feb 13, 2007 | 02:01 AM
BadLuckAudi's Avatar
maybe a belt tensioner or alternator bearing mine did it off and on and i never figured out what it was
Old Feb 13, 2007 | 02:09 AM
gotaudi's Avatar
WOW uber quick responce. I have an after market DV from Evolution motorsports the sound is their at idle sometimes. the belt for the alternator, PS, fan is tight so I dont know if it would/could be the belt tensioner.
I was thinking about taking the belt off the AC then running the car and see if it is their if it is then i would like to take off the belt to the alternator, PS, fan for a short time just to check if it is one of those (I would like to try to isolate the sound). remember i would not run the car very long with the belts off
how do you guys feel about this idea
thank you very much
Old Feb 13, 2007 | 02:17 AM
wood_e's Avatar
Around 5k rpm i have a humming noise in my car. I have no clue what it is but it might be the alt bearing...
yea that would probably help you figure out if its one of those, running a short time without those belts isnt gunna hurt anything
Old Feb 13, 2007 | 03:10 AM
gotaudi's Avatar
okay i took both belts off and it still makes the chiping/squeeling sound so i know it is not any of the belts. I have no idea i cannot hear the noise when the hood is open so i dont know where to look now.
the noise is their when you first touch the throttle for .2 seconds then gone, the noise is also their at idle after a minute or so
any ideas would be great
thank you guys
Old Feb 13, 2007 | 03:12 AM
woah you took the belts off that fast already?
Old Feb 13, 2007 | 04:04 AM
gotaudi's Avatar
took about 10 minutes... do you have any idea of where or what the sound could be????
thank you
Old Feb 13, 2007 | 04:20 AM
might want to check for axle play on the turbo?
