HELP please!! core support Q
Old Jan 17, 2007 | 10:52 PM
southcoast's Avatar
Default HELP please!! core support Q
im removing my core support to replace it with a new one from a minor accident but it broke the core support, is it OK if i remove the bumper brackets(dont want airbags going off or anything) what percautions should i take? i have bumper cover and lights removed already
Old Jan 17, 2007 | 11:05 PM
tractioncontrol's Avatar
Default RE: HELP please!! core support Q
The safest bet is to make sure you have the radio code, disconnect the negative post on the battery and wait 10 minutes to be sure the system has discharged all power. I'm sure you could disconnect the air bag ECU, or you can disconnect impact sensors and air bags without them going off but you still stand the chance of accidental discharge. It only takesone tenth of a volt to discharge a airbag.
Old Jan 17, 2007 | 11:50 PM
Trey25's Avatar
Don't worry the airbag won't go off on you. Remove the negative and you're good to go...I've actually forgotten to remove it before and nothing happened.
tnorm077
Feb 22, 2014 11:42 PM
lespaul2510
Feb 4, 2014 05:14 PM
BesI
Aug 22, 2012 02:29 PM
Prizmatik
Mar 11, 2012 03:32 PM
thrasher
Dec 1, 2008 02:06 PM
