Help !! slower than ever with my b6
Old Jun 25, 2007 | 11:55 PM
sirco's Avatar
Default RE: Help !! slower than ever with my b6
Cmmon guys dont leave me hanging
Old Jun 25, 2007 | 11:57 PM
headshok2002's Avatar
DV wouldn't throw a code... not that I know of, anyways.
And if he just dumped a bunch of cash on Unitronic, I doubt he's just gonna pick up and buy GIAC or APR...
I'm sure this is a simple fix. Get a boost gauge hooked up... and go from there.
Old Jun 25, 2007 | 11:59 PM
sirco's Avatar
ORIGINAL: headshok2002
So u think if the dv went that it would cause this ............. and is this so called Limp Mode a common problem wen flashing the car and keeping the rest bone stock?
Old Jun 26, 2007 | 12:18 AM
sirco's Avatar
Ne one?? more tips
Old Jun 26, 2007 | 09:21 AM
akielb's Avatar
Who's telling you that you are in Limp mode and how do they know? You will need to either disconnect the battery for a while to let the ECU reset(just the fault codes) or get a Vag-com cable and see if the ECU has any codes in it, just because you don't have a CEL doesn't mean your ECU isn't throwing codes. Get the DV replaced ASAP - either order a Forge or go to audi and pick up a 710n(upgraded TT version). If you DV fails your just letting boost leak out of the system.
#1 Get the DV changed
#2 Get a Boost Gauge so you know what your getting
#3 get a Vag cable so you can scan your car
Old Jun 26, 2007 | 09:48 AM
96audia4's Avatar
I think you might be in limp mode. Just disconnect the battery and then go for a test drive. I find it unlikely that the DV failed already, but I would replace it anyway since it will fail eventually.
joeyac02
Jul 29, 2012 08:08 PM
dOuchBaGd
Feb 1, 2009 04:16 PM
kriptonik
Aug 21, 2008 12:05 PM
S4LIFE
Aug 17, 2007 04:53 PM
headshok2002
Jun 17, 2007 02:07 AM
