help! something is wrong!
Old Dec 12, 2004 | 01:19 PM
CRAZYHAWK's Avatar
Default RE: help! something is wrong!
On level ground try starting in second gear. If the clutch slips it needs adjustment or its burned out.
Old Dec 12, 2004 | 09:20 PM
King_D's Avatar
the clutch is broken! the pressure plate cracking and breaking is the only clutch problem that would make it feel as if you were crushing a coke can. a cracked plate will also cause slipping and grinding/squeking/ scraping noises. Stop driving it now cuz if a peice breaks off it can get lodged in your tranny and you will destroy your transmission.
Old Dec 13, 2004 | 03:40 AM
sfordeso's Avatar
wow. what would you have to do to crack the pressure plate? i thought those things were nearly indestructable
Old Dec 13, 2004 | 03:53 AM
David_K's Avatar
no they are very britle. you can crack them several ways. if you add gobbs of power at one time (like the installation of a GT28RS kit) with out changing the clutch. the sudden change in power and torque would cause the plate to overload and crack. another possibility is overheatring the clutch. if he took off in 3rd gear for a whole day or two and it was cold outside so it cooled down quick and then he did the same thing the plate would crack from the temperature change. Another thing could ba a warped flywheel or a bad TOB.
Old Dec 13, 2004 | 04:15 AM
sfordeso's Avatar
huh. it's a good thing i read forums. not that i would ever take off in 3rd...
thanks david.
also (not too knowledgable on manual trannys) what about stripping gears? is it possible? wives tail? how much do you have to abuse it to do it?
Old Dec 13, 2004 | 04:20 AM
King_D's Avatar
yeah stripping gears can happen. the most common way to strip gears is if your shifter is loose and it doesnt fully pull the tranny all the way into gear. you will hear a grinding noise while shifting but once it almost gets into gear you will hear nothing. the next way is not fully putting it into gear while shifting fast. or letting off the clutch to early while tring to shift fast. the fastest way to do this id by shifting w/o the clutch. while you can perform this with no damage you have to know how to do it.
Old Dec 13, 2004 | 04:22 AM
sfordeso's Avatar
woah woah woah. that makes no sense, how can you shift without the clutch?
benefit would obviously be speed right? but how is it done
Old Dec 13, 2004 | 04:23 AM
  #18
sfordeso's Avatar
by the way, i have this BEAUTIFUL new sig, and you never even noticed damn you david. damn you
Old Dec 13, 2004 | 04:40 AM
  #19
King_D's Avatar
dude i saw it. jestnomen did a very good job. i requested he do that car for you
shifting without the clutch is hard but mustang driver and drag racers every where do it. i would not recommend this . i refuse to even try it
  #20
SlimChriz's Avatar
you can shift witout the clutch by accerateing real quik the let of the throttle real qiuk and shift it used to work on this chevy pickup my friend used to let me borrow...nevr tried it on an audi though.
