Help! Spare wheel really wobbly!
Old Nov 12, 2007 | 10:01 PM
mark_2328's Avatar
Default Help! Spare wheel really wobbly!
So I got a flat, and bent my rim. ****. Along with a new coil and/or ignition control module but thats a whole nother story. Anyways, I put my spare rim on, tightened the lug bolts all the way and start to drive, and the wheel sounds like its gunna fall off. So I jack it up again, and notice that the whole wheel itself is really wobbly. Think it might have to do with the lug bolts? I also found like a plastic ring (hub-centric ring maybe?) not sure if thats what they're called, but it was in my trunk. Tried putting the ring on over the hub (not very up on my terms here so bear with me) but I couldn't get the wheel on. I got angry, and didn't really have much time so I didn't try very long. I'll get pics tomorrow, but any suggestions? Thanks in advance.
Old Nov 12, 2007 | 10:56 PM
auditech79's Avatar
Default RE: Help! Spare wheel really wobbly!
Running after market rims?
Old Nov 12, 2007 | 11:06 PM
sean1.8t's Avatar
did you torque down the lug bolts? and did you torque them down in the correct star pattern? also, what he said^ what size tire on the spare and what size tires are on the rest of your rims?
Old Nov 12, 2007 | 11:37 PM
auditech79's Avatar
Earth to mark come in mark
Since you haven't replied i'll give you some possiblities
1. If you have stock wheels and you can't get the spare wheel on right you probably didn't get the wheel torqued correctly.
2. If after market you probably have centering rings which is getting in the way of the spare wheel, or you have after market lugs (longer than normal) which won't sit flush on a stock wheel, causing it to wobble.
Old Nov 13, 2007 | 12:28 AM
mark_2328's Avatar
Sorry, not sure if the lugs are longer than normal. But the rims were aftermarket, but now it is a stock spare, so they might very possibly be. The old wheels were miglia mmii's btw.
Old Nov 13, 2007 | 12:30 AM
auditech79's Avatar
The stock lug nuts are black, if you don't have the stock lug nuts the spare won't be flush/torqed against the hub.
Old Nov 13, 2007 | 12:36 AM
mark_2328's Avatar
Nope, these are silver/rust.. I'll see what I can dig up from the trunk. Anyone in the midwest looking to sell some winter wheels/tires?
Old Nov 23, 2007 | 05:44 PM
mark_2328's Avatar
They actually look black on second thought. Bought a set of stock 15"s today, and they are still really wobbly. Lug bolts are a little too long i believe. But they are black, so they are likely stock.. I'm angry.
cockney
B8 Models
Feb 4, 2014 05:46 PM
DewAudiA4
Oct 21, 2012 12:58 PM
billski
Jul 18, 2010 12:54 PM
twinturbosixer
Aug 17, 2009 11:10 PM
jetskidia
Jan 30, 2005 08:13 PM
