Help With System
Old Dec 6, 2006 | 12:51 PM
  #21
alias747's Avatar
Default RE: Help With System
NOOOOOOOOOOOOOO Don't do that!!! If you wire each voice coil to each terminal on the amp like that you are giving the amp a 1 ohm load. Which that amp is not rated to handle that low of a load. Like I said in my previous post. You have 1 Dual 2 ohm sub. There is NO POSSIBLE way to make a single 2 ohm load with 1 dual 2 ohm sub. The only possibilities are 1 ohm or 4 ohms. If you hook it up like Badluckaudi said you will get 1 ohm to the amp and it will eventually FRY the amp if not very soon. Just giving you a good warning. i hope you haven't already done it....
Old Dec 6, 2006 | 05:39 PM
  #22
BLRzAUDI's Avatar
No, I haven't done it already. OK so I guess 4 ohm is my only option. So, how do I do that?
Old Dec 7, 2006 | 01:55 AM
  #23
alias747's Avatar
If you want to know more about car audio and you need some help go to a car audio forum such as www.ecoustics.com. I am a avid member there. You will get results much faster. Otherwise for wiring your sub go to: http://www.the12volt.com/caraudio/wo...igurations.asp
Those are your 2 different options. Glad I could help and GL!
Sonita
May 3, 2015 05:58 AM
Polo2ya
Jan 10, 2014 08:33 PM
kellervernon
May 18, 2011 11:01 AM
boomshine
Oct 13, 2007 02:39 AM
headshok2002
10
May 20, 2007 01:15 AM
