Help..tranny probs..
Old Nov 13, 2005 | 02:32 AM
A4life's Avatar
Default Help..tranny probs..
OK....im just that new..the Tip transmission....is it activated when ya just put the gear selector in the + or - slot?....and if so..my tranny is either messed up or im doing something wrong...what is it....i hope it is jacked...now i can get my timing belt and tranmission fixed for the same co-pay...damn i happy i bought an extended warranty..
Old Nov 13, 2005 | 02:47 AM
Dave666's Avatar
Default RE: Help..tranny probs..
Yes , when you slide the shifter to the right , thats when its active.
Push it up to upshift , and down to downshift.
Whats is the tranny doing thats not right ??
Old Nov 13, 2005 | 03:49 AM
A4life's Avatar
its not doing anything...even the gear indicator selector on the dash isnt moving to gear...or anything...its like its not even connected[:@]
Old Nov 13, 2005 | 04:55 AM
dankhound's Avatar
Are all the gear lights lit up? Does the transmission even function normally?
Old Nov 13, 2005 | 05:31 AM
A4life's Avatar
yes it funtions correct....when i just manually shift it in other then in tip mode..and the lights work correctly also in this manner... its just when i put it into tip mode..dont do anything ....its like it starts in 5th gear..and when i try to select down to 2nd...the light dont move...and nada .....quite frustuating..and my steering wheel has the selector also..the + and - but still nada..like i said tho the transmission works fine in normal auto mode....no rough shifts..or anything of the sort, its basically like the tip dont exist..[&:]
LCR
Jul 24, 2012 10:57 PM
The6
May 10, 2007 10:01 PM
18ToHATE
May 31, 2006 10:35 PM
Jim Clark
Feb 5, 2006 06:10 PM
Flip_x
Nov 10, 2005 11:23 PM
