HELP! tranny woes
Old Aug 15, 2007 | 01:44 AM
blakhaüs's Avatar
Default HELP! tranny woes
i own an 01 2.8Q Avant w/ 51000 miles
heres the story...
lastweek i was at a stop sign waiting to pull into traffic. when i got the chance i pulled out and felt a huge thud like someone rear ended me or something. i looked in my rear view and noone was there. i suddenly felt the car get sluggish like it didnt want to pick up with my foot mashing the gas pedal. i put the car in tip mode and noticed it didnt function. i dropped it into all gears and only PRND worked. the display on the cluster still has the D highlighted no matter what gear i select. now the car feels like its stuck in third as when i went to launch it was very sluggish. when i get up to speed it feels ok but i drove on the highway doin 65 @ 3700 rpm so im guessing it wont get into fifth gear. i believe i might be in limp mode as i read some similar occurances when i did a search onother boards.
i had the car vag'ed by a friend and this is what i got:
Tuesday,07,August,2007,18:19:31:21001
VAG-COM Version: Release 704.1
Data version: 20070629
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 3B0-907-551.LBL
Part No: 3B0 907 551 BQ
Component: 2.8L V6/5V G 0001
Coding: 07251
Shop #: WSC 63351
5 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
16689 - Cylinder 5: Misfire Detected
P0305 - 35-10 - - - Intermittent
18034 - Powertrain Data Bus: Missing Message from TCU
P1626 - 35-10 - - - Intermittent
17658 - Fuel Level too Low
P1250 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.LBL
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00160
Shop #: WSC 08101
Address 15: Airbags Labels: 8D0-959-655-AI8.LBL
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 2002
Coding: 00306
Shop #: WSC 63351
Address 17: Instruments Labels: 8D0-920-xxx-17.LBL
Part No: 8D0 920 980 QX
Component: B5-KOMBIINSTR. VDO D12
Coding: 02262
Shop #: WSC 08101
1 Fault Found:
01315 - Transmission Control Module
49-10 - No Communications - Intermittent
Address 35: Centr. Locks Labels: 8L0-862-257.LBL
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16232
Shop #: WSC 40801
7 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
thanx for reading and any help is greatly appreciated.
Old Aug 15, 2007 | 01:49 AM
auditech79's Avatar
Default RE: HELP! tranny woes
Your in transmission limp mode, either the fuse/relay to the TCM is bador the TCM needs to be replaced.
Old Aug 15, 2007 | 01:59 AM
blakhaüs's Avatar
where can i find the fuse/relay? and about how much is a new tcm?
Old Aug 15, 2007 | 11:56 AM
blakhaüs's Avatar
anybody know where the fuse/relay for the tcm is?
Old Aug 15, 2007 | 02:16 PM
david9999's Avatar
I don't have my wiring diagrams handy. Most of the codes are probably ancient. The important one is 18084. Your transmission is in LIMP mode and only 4 gear and reverse will work. Clear the codes and see if that solves the problem. The Tcu is on the floor front passenger side. If your car gets water in it, it often shorts out. Have you driven through very deep puddles?
Old Aug 15, 2007 | 02:33 PM
blakhaüs's Avatar
ive had the codes cleared but nothing happened. i checked the tcu and pulled it out. nothing is damp or corroded. ive driven through some hard rain but no puddles over 2 inches.
Old Aug 15, 2007 | 04:39 PM
david9999's Avatar
I wont be home until tomorrow at which time I can look up codes
Old Aug 15, 2007 | 11:42 PM
blakhaüs's Avatar
thanx bro. any help is appreciated.
Old Aug 17, 2007 | 11:45 AM
blakhaüs's Avatar
bump.[&o]
Old Aug 17, 2007 | 12:48 PM
david9999's Avatar
Sorry I haven't made it home. ON an extended business trip.
Nemick
Sep 11, 2012 05:33 PM
3ddude
Jun 12, 2011 09:16 AM
nhill2090
Jun 30, 2009 11:48 PM
Entrical
Sep 27, 2007 12:34 PM
Hey_You
Sep 12, 2007 08:20 AM
