HELP w/ Headlights --- PLEASE ---> Tempermental !!! REWARD - $1
Old Jul 31, 2006 | 10:14 PM
TurboMeTroy's Avatar
Default HELP w/ Headlights --- PLEASE ---> Tempermental !!! REWARD - $1
Sometimes they work, and sometimes they don't.
I know there is an issue with the switch in the column....could that be it, making them work only on certain days?
Short somewhere? Ground coming loose?
Faulty relay??
Anything would help. I can't be out after dark because I never know if my frickin headlights will work!!!!!!
Please Help.
Thanks in advance,
Troy
Old Jul 31, 2006 | 10:22 PM
Default RE: HELP w/ Headlights --- PLEASE ---> Tempermental !!!
I know SOMEone is online, any ideas at all?????
I was hoping to get some rather quick replies here!!
Any ideas of where to check 1st!!!???
Old Jul 31, 2006 | 10:25 PM
Please......anyone. Someone keep the spirit of beneficial forums alive........
Old Jul 31, 2006 | 10:34 PM
evoic's Avatar
I don't know jack about your car and I don't want the $1.
But since you're looking for ANY kind of reply, here's probably why you're not getting an answer:
It could be all of the things you listed.
Until someone gets in there and addresses each of the possible issues, there's no way of being certain.
Where do you live? Maybe one of the local guys can help take a look.
Old Jul 31, 2006 | 11:15 PM
I'm aware that it could be ANY of the things I suggested, but I thought SOMEONE might have had similar problems and might be able to save me some time.
I'm in Minneapolis.
ANY suggestions would be greatly appreciated.
Cheers,
Troy
Old Jul 31, 2006 | 11:23 PM
Default RE: HELP w/ Headlights --- PLEASE ---> Tempermental !!! REWARD - $1
ORIGINAL: TurboMeTroy
Troy
I meant that I am aware other people have had issues with their switches in the column, but mine appears to be working properly.
Old Aug 1, 2006 | 04:36 AM
Um.....
Old Aug 3, 2006 | 09:36 PM
help.
help.help.
Old Aug 4, 2006 | 03:25 PM
oleafo's Avatar
There could be a large number of things that might be the problem, electrical gremlins are one of the most frustrating problems to solve. It takes time, details, and know how to find the solution. If you're not used to electrical wiring then I would suggest finding a shop to help you out. Sometimes it's just a loose cable in front of you and sometimes it's that one harness that's hiding behind the dash that requires taking the entire thing apart to get to it.
Old Aug 4, 2006 | 07:40 PM
SilverPullit's Avatar
try popping the plastic cover off of the drivers side of the dash where it meets the door jam. stick your hand in there and wiggle the wires connected to the headlight switch in the dash and see if the lights filicker. if they do then repair/replace the switch or check the wires to see if they are broken.
VW01AUDI00
Nov 11, 2017 08:38 AM
gone postal
Jul 22, 2010 10:34 PM
Big_Al_TT
Apr 30, 2008 05:58 PM
WishIWasRWD
Aug 10, 2007 09:57 PM
WishIWasRWD
Aug 10, 2007 03:33 PM
