Help with Xenon Lights
Old Jan 4, 2007 | 11:29 PM
cstarky15's Avatar
Default Help with Xenon Lights
Alright so i buy my 01 audi A4 and the low bulbs are xenon but the high beams and fog lights are not. How do i know which kind of xenon to use on my car? i was told H7 as long as it is low voltage cuz high can mess up/ melt the wires.
Old Jan 5, 2007 | 12:05 AM
96audia4's Avatar
Default RE: Help with Xenon Lights
If it came from the factory with xenon, the low beams are D2S. If you want to convert the high beams to xenon, you will need a H7 conversion kit.
Old Jan 5, 2007 | 12:10 AM
cstarky15's Avatar
Is there any way just to get H7 bulbs and plug and play? or do i have to do the conversion kit?
Old Jan 5, 2007 | 12:59 AM
96audia4's Avatar
EDIT:
I think you will need a seperate conversion kit for the high beams (definitely not plug and play). I just bought a kit from Visionbulbs.com for $200 shipped (on sale). I'm not sure if they are still on sale but you can check. Normally they cost ~260ish (I think). The installation is easy and it is a good quality product. Hope this helps.
https://www.audiforums.com/m_371917/tm.htm
Old Jan 5, 2007 | 01:26 AM
cstarky15's Avatar
I bought my 01 audi used from a dealership so i dont know if the person b4 me did a conversion for the lights. i know that the 01 had the option to get xenon lights which im assuming they did. if thats the case do i still need the conversion kit? if i didnt do the conversion what would happen? the lights just not turn on or would it mess my wires up?
If you go to this site from sylvania and do your make and model it tells you what kind of bulbs you can use. this is the link for my car. http://www.sylvania.com/ConsumerProd...RG-Results.htmit tells me i can use H7's in my car. am i just really confused or what?
Old Jan 5, 2007 | 02:06 AM
01A4T's Avatar
ORIGINAL: cstarky15
Most '01 a4's do not have the low beam xenons..... it is an option, and i have seen only a few 1.8T's with the low beam 4300k around my area.... most are halogen projectors.... never the less you will need the conversion kit for bi-xenon
Old Jan 5, 2007 | 02:58 AM
swift_A4's Avatar
sorry to post take but... i know my low beam xenons are d2r if you just buy say replacement 6000K d2r bulbs it is just plug and play to install?
Old Jan 5, 2007 | 03:56 AM
AteUrV8's Avatar
ORIGINAL: 01A4T
ORIGINAL: cstarky15
mmmmm.....drool, my 01 a4 has xenons and they are gorgeous.
Old Jan 5, 2007 | 04:23 AM
96audia4's Avatar
ORIGINAL: cstarky15
Whether your car came with xenon (it probably did) or the previous owner did a conversion kit, you will still need a seperate conversion kit. The reason is that each bulb needs a different ballast. If you tried to plug in xenon bulbs into your regular high beams, they would not ignite. A ballast is used to generate extremely high voltages to ignite and power xenon bulbs. Also, if you buy a conversion kit, it will come with special wiring that is safe and can handle the voltage. Hopefully I'm not being too confusing [sm=icon_blah.gif]
Old Jan 5, 2007 | 04:26 AM
96audia4's Avatar
ORIGINAL: swift_A4
Yes, it is plug and play.
