Here it is! Boost leakage proof *UPDATED*
If your boost gauge does this
http://video.google.com/videoplay?do...46493294099405
then you probablyhave a boost leak
well from what i have heard over and over is that the boost should hold at 14-15 and spike around 15-16.
If im wrong and i dont have a boost leak, please tell me.
and mine spikes at 15 and falls to 10-12 really fast and my 0-60 is around 10 sec. with a chip
Mine definately does not do that. I hold 18-20psi with the pedal to the floor throughout the rpms. Your 0-60 should be around 8 seconds, or 7ish if you are trying to kill your tranny.
Ok. According to the local audi specialist. I DO NOT have a leak.
He said that you are suposed to loose boost like i do, and if you don't you could blow.
Anyopinions on this?
So my question is, what is making your cars hold your boost?
your N75 valve.
the wastegate is set to open at a very low amount of boost, maybe 5 psi. the N75 basically fools the wastegate actuator into thinking that there's less boost than there really is, so you can run more pressure than the wastegate allows.
so should i get a N75H like onepoint8tee.
or should i get the N75J.
what is the difference between the two?
is it easy to install by yourself without a lift?
sorry for all the questions
