Here it is! Boost leakage proof *UPDATED*
Old Mar 21, 2007 | 10:10 PM
scotts custom's Avatar
Default Here it is! Boost leakage proof *UPDATED*
If your boost gauge does this
http://video.google.com/videoplay?do...46493294099405
then you probablyhave a boost leak
Old Mar 21, 2007 | 10:29 PM
Audi_Skydiver's Avatar
Default RE: Here is it! Boost leakage proof
Are you talking about how it drops really fast???
Josh
Mine does that[]
Old Mar 21, 2007 | 10:30 PM
Bondga's Avatar
mine drops off but not that fast, hmm..... i wonder
Old Mar 21, 2007 | 10:32 PM
well from what i have heard over and over is that the boost should hold at 14-15 and spike around 15-16.
If im wrong and i dont have a boost leak, please tell me.
and mine spikes at 15 and falls to 10-12 really fast and my 0-60 is around 10 sec. with a chip
Old Mar 21, 2007 | 10:35 PM
The Bishop's Avatar
You don't have a leak. it's just the k03 running out of breath at high rpms, they all do that.
Old Mar 21, 2007 | 10:55 PM
ultrasport's Avatar
mine spikes to 19 then holds at 16-17 psi, only drops down slowly at high rpms, that def looks like a boost leak to me.
Old Mar 21, 2007 | 11:34 PM
onepoint8tee's Avatar
Mine definately does not do that. I hold 18-20psi with the pedal to the floor throughout the rpms. Your 0-60 should be around 8 seconds, or 7ish if you are trying to kill your tranny.
Old Mar 22, 2007 | 11:43 PM
Ok. According to the local audi specialist. I DO NOT have a leak.
He said that you are suposed to loose boost like i do, and if you don't you could blow.
Anyopinions on this?
So my question is, what is making your cars hold your boost?
Old Mar 22, 2007 | 11:50 PM
Belligerenceā„¢'s Avatar
your N75 valve.
the wastegate is set to open at a very low amount of boost, maybe 5 psi. the N75 basically fools the wastegate actuator into thinking that there's less boost than there really is, so you can run more pressure than the wastegate allows.
Old Mar 22, 2007 | 11:59 PM
so should i get a N75H like onepoint8tee.
or should i get the N75J.
what is the difference between the two?
is it easy to install by yourself without a lift?
sorry for all the questions
