hi guys...new here. a leaky question???
i own a 99.5 A4 2.8 with 76K. i just replaced the valve cover gaskets this weekend along with the breather hose (mine was taped in 3 places). everything went pretty smooth ( thanks to your DIY forum) and now my car smells and drips worse than before. i did read about some guys using rtv sealant but my gaskets didnt have any on them when i took them off so i didnt put any on the new gaskets. could this be causing them toleak worse than my old gaskets?? any other ideas would be GREATLY appreciated. thanks in advance guys.
ORIGINAL: wood_e
Quite possible that the new gasket on sharp bends mises in a few spots. Check the VC gaskests for leaking.
Its called high temp silicon RTV should be grey in color.
ORIGINAL: Belligerenceâ„¢
it's never a bad idea, just make sure to use one that's oil and fuel resistant.
ORIGINAL: audichicks4
does this mean i should use rtv????
i dug back into the VCG and found that a piece of heat shealding on the passenger side got sandwiched in there when i put the vavle covers back on. OOPS. anyway i think that was the problem.
