HomeLink
Old Dec 28, 2005 | 09:27 PM
mjvss21's Avatar
Default HomeLink
hey has anyone had trouble programming their homelink garage door opener in there a4s, mines giving me a hard time wondering if anyone else has conquered the problem
Old Dec 28, 2005 | 10:02 PM
S_R_N83's Avatar
Default RE: HomeLink
Check and make sure that your garage door opener doesn't require that you press a "program" button or something of that sort before you try to program it with your homelink.
Old Dec 28, 2005 | 10:45 PM
cary12's Avatar
I'm in the same boat man. My home link doesn't work for some reason. My garage has a program button that you push and then it gives you 30 seconds to program the homelink and it didn't work.
Old Dec 28, 2005 | 10:54 PM
S_R_N83's Avatar
Did you have someone help you with pressing the program buttom? Maybe you're running out of time if you're trying to do it by yourself?
Old Dec 28, 2005 | 11:14 PM
ckandes1's Avatar
i just programmed mine a few days ago. it would be called the 'learn' Button on your garage door motor. Some garages require that you press your homelink button up to 3 times in that 30 seconds, read your garage motor manual. also make sure you are pressing all the right buttons etc.
Mine works fine with 2 seperate garages and the front gate of my community. The garages needed to 'learn' the homelink system, and in my case the 'learn' button is hidden inside the motor light encasement.
Old Dec 28, 2005 | 11:25 PM
StevenTownsend's Avatar
yeah mine works fine and 2 of the 3 garages are programmed.
Old Dec 28, 2005 | 11:32 PM
ZedEx's Avatar
Mine didn't work either... Which I kind of figured, seeming as I saw an imprint on the driver's side visor where the previous owner had their garage door opener. I seriously cannot figure it out.
Old Dec 28, 2005 | 11:37 PM
apg96's Avatar
if it doesnt work u may have rolling codes, my dads range rover's doesnt work and i dont think my moms new a6 works either b/c of the rolling codes. I dont have it so i dont care.
Old Dec 28, 2005 | 11:44 PM
VitaminB6's Avatar
I had a hell of a time getting it programmed. Turned out the openers had rolling codes - used a combination of instructions on the opener (yep, there was a "learn" button) and instructions I got from homelink.com. See previous discussion on this topic for more info.
Old Dec 29, 2005 | 03:06 AM
mjvss21's Avatar
yea i looked on my garage door opener and i didnt see any learn button, could it be on the top that is connected to the ceiling, or do i have to take off a light panel or something? any of you guys have a hard time finding it? my garage door motor cant be more the 5 years old
