HomeLink
I'm in the same boat man. My home link doesn't work for some reason. My garage has a program button that you push and then it gives you 30 seconds to program the homelink and it didn't work.
i just programmed mine a few days ago. it would be called the 'learn' Button on your garage door motor. Some garages require that you press your homelink button up to 3 times in that 30 seconds, read your garage motor manual. also make sure you are pressing all the right buttons etc.
Mine works fine with 2 seperate garages and the front gate of my community. The garages needed to 'learn' the homelink system, and in my case the 'learn' button is hidden inside the motor light encasement.
I had a hell of a time getting it programmed. Turned out the openers had rolling codes - used a combination of instructions on the opener (yep, there was a "learn" button) and instructions I got from homelink.com. See previous discussion on this topic for more info.
yea i looked on my garage door opener and i didnt see any learn button, could it be on the top that is connected to the ceiling, or do i have to take off a light panel or something? any of you guys have a hard time finding it? my garage door motor cant be more the 5 years old
