Hot A4
Old Jun 26, 2005 | 07:49 PM
veesixer's Avatar
Default Hot A4
I have a V6 A4 that's getting too hot under load (driving at around 80mph). The gauge is creeping steadily beyond the halfway point and I strongly suspect it would overheat if I dared to go far enough in it. I've just had both fans fixed but this makes no difference at fast speeds. Thermostat, water pump and gauge are all ok, and there are no signs of head gasket failure. Any input would be much appreciated.
Old Jun 26, 2005 | 08:57 PM
PaulA4's Avatar
Default RE: Hot A4
No fault codes? Vacuum leaks making it run lean?
Old Jun 26, 2005 | 09:36 PM
veesixer's Avatar
Default RE: Hot A4
Hi Paul, will check fault codes through climate control display tomorrow. Will vacuum leaks show up on this?
Old Jun 26, 2005 | 11:37 PM
TomRitt's Avatar
Default RE: Hot A4
coolant temp sensor. Common problem on the 1.8ts dunno of the 2.8 uses the same thing
