how to disconnect abs?
Old Oct 2, 2007 | 10:28 AM
mr666's Avatar
Default how to disconnect abs?
hi. i have an a4 ts quattro -00 and i want to disconnect my abs-system for the vintertime. i have tryed to pull the fuse and that works but i cant stand al of the beeping and consistant warning on the display.
is ther a better way to do this or can i go to v.a.g and have them whipe out the warnings?
later on i want to put in a switch so i can turn on or off the abs whenever i like.
thank you
Old Oct 2, 2007 | 10:58 AM
techbod's Avatar
Default RE: how to disconnect abs?
as a tech I couldn't tell you how to pull the wiring harness from the ABSECU and no way I can tell you to disconnect the bleeper its better to leave it on
Old Oct 2, 2007 | 11:53 AM
hiwords's Avatar
hardwire a switch to the abs module.
Old Oct 2, 2007 | 12:09 PM
acetrebo's Avatar
Why the hell would you want to do that?
Are you trying to total your car so you can get a new one or something?
Nothing like sliding out of control and not being able to stop.
Old Oct 2, 2007 | 03:46 PM
mr666's Avatar
ORIGINAL: hiwords
can you be more specifik about which wire to jack in a switch? or wher i can find more info about it.
i have tryed to remove one abs-sensor at the weel but the result was the same as if i removed the fuse...
haha, i know someone woud say that. =) when playing around in the snow and drifting alot the abs is a big dissadvantige!
if someone dosent agree whit me you don´t have to. but i like the way the car handles whitout abs! and i have been driving 4wd for 10 years now.
i hope that this tred can stay on topic. i want to know how to disconnect the abs whitout havin a cristmastree of lights and beeps in the car. if ther is a way to do this at al...
Old Oct 2, 2007 | 09:22 PM
Trey25's Avatar
Its possilbe, but I really wouldn't recommend it.. I've disconnected mine before, and blocked out the lights, but the beep still remained.
Old Oct 3, 2007 | 12:08 AM
apr_a4's Avatar
ORIGINAL: Trey25
i share the pain luckily my dad knows this guy at junkyard and i got the module for 250 with matching numbers
Old Oct 3, 2007 | 12:24 AM
hiwords's Avatar
i couldn't tell ya which wire sry. im thinking if u have the car off but the key in the on position, the abs light comes on. i forget, does it stay on? well if it does stay on, it means the module is getting power so u can get a volt meter and test each wire to see which one is the power one. that might work. however there is a wire that goes to the ABS pump. that wire might work. sry im not an abs specialist yet
Old Oct 3, 2007 | 06:17 AM
mr666's Avatar
ORIGINAL: Trey25
and how exaktly did you do that?
Old Oct 3, 2007 | 06:20 AM
mr666's Avatar
ORIGINAL: hiwords
yes i´m alsow thinking about cutting power direktly to the abs-pump.
