How do get the oxygen sensor off?
Old Sep 5, 2005 | 05:18 PM
david9999's Avatar
Default How do get the oxygen sensor off?
Either I need to eat my wheaties or someone superglued it in.
Old Sep 5, 2005 | 06:51 PM
TomRitt's Avatar
Default RE: How do get the oxygen sensor off?
22mm i believe, maybe 24mm, just get a good sized wrench on there
Old Sep 5, 2005 | 07:19 PM
david9999's Avatar
Have a oxygen sensor wrench but the sensor is stuck
Old Sep 5, 2005 | 07:23 PM
BzeA4's Avatar
david, where'd you get your o2 sensors? I'm going to be changing mine in the next week or so too.
Old Sep 5, 2005 | 07:32 PM
david9999's Avatar
I have the ATW engine, so I went with the VW sensor for 22 dollars. It wont work for your engine.
You can try ECS tuning alternatively oxygen sensors dot com
Old Sep 6, 2005 | 01:39 AM
onepoint8tee's Avatar
How did you know you needed an 02 sensor(s)? Did you get a check engine light?
Old Sep 6, 2005 | 01:47 AM
BzeA4's Avatar
I got a CEL, and used a obdII reader and got the code and searched and found out its my o2 sensor.
headshok2002's Avatar
ORIGINAL: david9999
you mean there are pro's to having the ATW engine!? SWEET.
Old Sep 6, 2005 | 03:47 AM
sandman's Avatar
spray it w/ wd40 and let it soak for a day then give it a try.
Old Sep 6, 2005 | 04:18 AM
flyinb501's Avatar
I'm waitng for mine from ecs tuning right now. Should be here any day.
