How do i install a BOV in an Audi A4 B5?
Old Dec 11, 2010 | 10:01 PM
  #21
Jbliss85's Avatar
try namotorsports.com for the forge hybrid bov/dv, you can set it to whatever settings you want but i believe it comes from factory set as 25% atmosphere and 75% recirculation best of both worlds
Old Dec 15, 2010 | 01:43 PM
  #22
Mike-2ptzero's Avatar
Forge Splitter doesn't have any adjusments for the BOV/BPV part. It is either 75/25 or 100 either way if you spin the bottom to block one of the outlets, remove the outlet and use the plug they supply. I thought it was adjustable like the GFB FX stealth till I read the instructions from Forge. The only adjustment on the Forge Splitter is for the spring tension.
You can see that info on a vid here or read it on this PDF file.
Old Dec 19, 2010 | 04:11 PM
  #23
Gotti's Avatar
im in the same boat here.. i read somewhere cant find it now but i read from one of you guys that an ECS Tuning Diverter valve is best to get and the for the "woooosh" sound that a bov gives i should get a Diverter Valve Spacer.. is this correct? would that setup give me the benefit of the sound as well as not messing up the maf readings?? if so does anyone have any links they would be able to hook me up with to purchase these?
Old Dec 26, 2010 | 04:59 PM
  #24
caodan2010's Avatar
you people have problems i swear.... let people choose what they want dont tell them what you think unless thay ask you. And no i meant a BOV""" Agreed..
AudiKid93
Aug 25, 2012 10:28 AM
3xpo
Nov 26, 2011 04:41 AM
andresol
B7 Models
Jan 18, 2011 09:09 PM
Sebasco2
Jun 8, 2008 05:05 PM
reddewman
Feb 19, 2005 12:51 AM
