how do i pressure test
Old Apr 8, 2006 | 09:23 PM
ecksman's Avatar
Default how do i pressure test
tried searching but couldnt find a direct answer
Old Apr 9, 2006 | 12:19 AM
dankhound's Avatar
Default RE: how do i pressure test
Assuming your talking about the cooling system you need a pump and an adapter to screw onto your overflow bottle. You pump it up to about 1 bar and see if it holds. If it holds all is good. If it drops you have a leak.
Old Apr 9, 2006 | 01:54 AM
trailboss's Avatar
^^ that or pressure test for boost leaks, i used this and its done the job for 2 years now click
Old Apr 11, 2006 | 02:02 AM
ecksman's Avatar
im talking about my 12v, cause based on my the codes i got its telling me i got leak some where on the intake side and i wanted to find out where, hopefully a gasket or something stupid like that
Old Apr 12, 2006 | 01:57 AM
dankhound's Avatar
Well youdont really presssure test a 12v because there is no turbo. What your looking for is a vacuum leak test. Best way to do that is to spray brake clean around the intake. The idle will either drop suddenly or rise suddenly if brake clean is sprayed into a leaky area.
Old Apr 14, 2006 | 03:35 AM
ecksman's Avatar
i heard that too but with starter fluid, what do u think i'm def gonna give it a shot
brob
Feb 7, 2012 07:14 PM
drobrt
Nov 18, 2009 11:49 PM
madman1234509
Apr 23, 2009 12:45 PM
m5racer
Aug 14, 2006 02:59 PM
khj677turbo
Aug 2, 2006 01:19 PM
