How do u lower a audi without the suspension arms rubbing on the tires??
Subscribe
Sep 29, 2005 | 03:04 PM
Someone please explain this mod to me cause no way the suspension could come down 2 inchs on my car it would be sitting on the tires!!!! Help? I want to drop but my dad and i are wondering how it will work out???
Reply
Sep 29, 2005 | 04:10 PM
RE: How do u lower a audi without the suspension arms rubbing on the tires??
the coilovers controll the entire suspension, arms and all, the distance between the arms and the tire is pretty much set, the only way your gonna rub, is if you like drop it to the ground.
but for 2 inches, you pretty much ok...
search the fourms for good companies for parts...
Reply
Sep 29, 2005 | 04:29 PM
how down you wanna go ? I dropped about 2" at front (I have about a half finger gap between fender and the tire) and no rubbing or something but you MUST roll the fenders.
Reply
Sep 29, 2005 | 10:28 PM
There is about a mm of clearance on mine.
Reply
Oct 3, 2005 | 01:49 AM
Will my suspension bottom out?? What rims r u all runnin on ur b5's????
Reply
Oct 3, 2005 | 03:02 AM
yeah the control arm and the tire don't really get much closer as you drop the car... however, like flyboy said... you can get pretty close. Him and I are both running 8.5" wheels, so as the width increases, you get CLOSE to that control arm...
I'm the same way, with about 1mm of clearance.
I run 235/45/17's... he's got 18's.. what size tire do you run flyboy? 225/40/18 or 235?
Reply
Oct 3, 2005 | 03:32 AM
I wish I had suspention. You ment flyinb5
Reply
Oct 3, 2005 | 03:48 AM
Yeah, I run 235's.
Reply
Oct 3, 2005 | 03:49 AM
I also run 235's they are just on 16's
Reply
Oct 3, 2005 | 05:33 AM
got tein s-tech springs...so thats 2.4 int hefront...any rubbing problems possiblly...17 inch rims.
Reply
