How do u lower a audi without the suspension arms rubbing on the tires??
Old Sep 29, 2005 | 03:04 PM
Godfather's Avatar
Default How do u lower a audi without the suspension arms rubbing on the tires??
Someone please explain this mod to me cause no way the suspension could come down 2 inchs on my car it would be sitting on the tires!!!! Help? I want to drop but my dad and i are wondering how it will work out???
Old Sep 29, 2005 | 04:10 PM
luvin_the_rings's Avatar
Default RE: How do u lower a audi without the suspension arms rubbing on the tires??
the coilovers controll the entire suspension, arms and all, the distance between the arms and the tire is pretty much set, the only way your gonna rub, is if you like drop it to the ground.
but for 2 inches, you pretty much ok...
search the fourms for good companies for parts...
Old Sep 29, 2005 | 04:29 PM
aRIf's Avatar
how down you wanna go ? I dropped about 2" at front (I have about a half finger gap between fender and the tire) and no rubbing or something but you MUST roll the fenders.
Old Sep 29, 2005 | 10:28 PM
flyinb501's Avatar
There is about a mm of clearance on mine.
Old Oct 3, 2005 | 01:49 AM
Godfather's Avatar
Will my suspension bottom out?? What rims r u all runnin on ur b5's????
Old Oct 3, 2005 | 03:02 AM
headshok2002's Avatar
yeah the control arm and the tire don't really get much closer as you drop the car... however, like flyboy said... you can get pretty close. Him and I are both running 8.5" wheels, so as the width increases, you get CLOSE to that control arm...
I'm the same way, with about 1mm of clearance.
I run 235/45/17's... he's got 18's.. what size tire do you run flyboy? 225/40/18 or 235?
Old Oct 3, 2005 | 03:32 AM
flyboy's Avatar
I wish I had suspention. You ment flyinb5
Old Oct 3, 2005 | 03:48 AM
flyinb501's Avatar
Yeah, I run 235's.
Old Oct 3, 2005 | 03:49 AM
flyboy's Avatar
I also run 235's they are just on 16's
Old Oct 3, 2005 | 05:33 AM
Slowb5's Avatar
got tein s-tech springs...so thats 2.4 int hefront...any rubbing problems possiblly...17 inch rims.
