how do you replace the 97 A4 fuel pump?
Old Apr 23, 2006 | 11:15 PM
ganicki344i's Avatar
Default how do you replace the 97 A4 fuel pump?
Fuel pump is out in the A4 anyone have the instructions on how to replace??
Thanks G
Old Apr 25, 2006 | 04:41 PM
dankhound's Avatar
Default RE: how do you replace the 97 A4 fuel pump?
Get fuel level below quarter tank. Remove rear seat bottom by pulling it out of clips. On passneger side there is a black cover with three screws. Remove it. Theres a special tool to remove ring around sender cover but use your imagination and youll be able to get it off. Remove any hoses and wires that do not go to the pump. To remove the pump it is necessary to turn it about an eighth of a turn counter clockwise. There is also a special tool to perform that function.
Old Apr 25, 2006 | 04:49 PM
north5995's Avatar
There a DIY over on www.audiworld.com under the tech section.
skihigh2299
Oct 11, 2015 05:54 PM
skihigh2299
Sep 25, 2015 12:09 AM
jsethwerner225
Nov 14, 2014 01:55 PM
grahamtwatson
Nov 26, 2009 11:23 PM
willbert7
Nov 9, 2008 11:35 AM
