How do you smoke your tail lights?
Old Jul 28, 2005 | 03:51 PM
YFZFourFifty's Avatar
Default How do you smoke your tail lights?
Ive seen a couple of your guys BLACK cars on this site and they look much better with smoked tail lights or TINTED tail lights.
How do i go about darkening the tail lights?
Old Jul 28, 2005 | 04:44 PM
phroztbyt3's Avatar
Default RE: How do you smoke your tail lights?
two ways... 1.. buy the smoked tail lights (1/2 good idea 1/2 bad)..... 2nd.... take off your headlights.. and literally use tint film.. there might b sum more ways but i dont know them
Old Jul 28, 2005 | 04:52 PM
initialdtm's Avatar
VHT NiteShades. Then clearcoat. NiteShades comes in a spray can, you just clean your tails REALLY good (after you take them off the car, of course), then spray some coats of this on, then clearcoat for a shiny look.
Old Jul 28, 2005 | 05:36 PM
Will it smear or run because that sounds pretty hard to do. Will the paint be affected when rained on?
What kind of clear coat?
Tint film makes more sence to me but i dont know how i would curve it around the tail light. I want a A+ job.. not somthing stupid
Old Jul 28, 2005 | 05:42 PM
juju4uofa's Avatar
It'll only run if you spray to much at one time. Spray a couple of thin coats and let it dry "flash" for about 10 min. Then keeping repeating this process until you've reached the desired tint. Then spray with clear using the same procedure. If you've never painted anything you should read some type of tutorial on the correct way to spray. It's not hard though. Oh, and rain won't affect it. If you paint it right the rain will bead up just like your car.
Old Jul 28, 2005 | 09:04 PM
Thanks a lot.. What clear coat should i use? Does VHT make one that i should use?
Old Jul 29, 2005 | 01:16 PM
david9999's Avatar
EZ double-wide
Old Jul 29, 2005 | 03:14 PM
initialdtm's Avatar
I just used regular old clear coat that I bought at ACE Hardware...seemed to work out fine. And have you ever actually touched tint film? It's so thin and flimsy that I bet if you powerwashed your car you'd take em off. Spray on is the best way to go for exterior lights.
Boo_Cocky
Aug 31, 2013 07:09 PM
Adams42
Jun 26, 2010 02:05 AM
jaw knee
Mar 23, 2009 12:34 PM
gsmith23
Jun 3, 2006 11:00 PM
BDawg A4
Jan 3, 2005 10:40 PM
