How do you tell if your turbo is out?
Old Jan 10, 2006 | 02:54 AM
gregp1962's Avatar
Default How do you tell if your turbo is out?
OK, My car is running like crap. I suspect that the turbo is out. It accelerates from 0-60 in about 1/2 hour. I hooked up an makeshift boost gauge and it confirms no boost. I can't feel any play in the wastegate rod. How do I know if the turbo is shot or if something else is prententing the turbo from working? Could it be the N75? Anything else? BTW, no CEL.
Old Jan 10, 2006 | 03:00 AM
Peteman187's Avatar
Default RE: How do you tell if your turbo is out?
If your turbo is shot there is usually a bluish smoke comming from your exhaust. Check your turbo inlet pipe. When you hooked up the boost gauge what vaccum where you reading? When you say no boost would it go from 20 vaccum to 0 or what.
Old Jan 10, 2006 | 03:02 AM
gregp1962's Avatar
Yes, the gauge reads somehwere around 20 vacuum to zero.
What do I check in the inlet pipe?
Old Jan 10, 2006 | 03:13 AM
FASTER's Avatar
Tech Slut
after driving my audi for like 20 minutes at night while it wasn't boosting(diverter valve had no noise either obv.) i popped the hood and looked at my housing, glowing like a fire poker straight from the fire, i mean orange and glowing. now this was also while driving with a blown cat, so the heat could have been backing up from the cat, and the turbo probably blew because of the cat being blown and not fixing it or vise versa, either way the car made no boost when any of this was going on.
Old Jan 10, 2006 | 03:28 AM
primo537's Avatar
sorry im new, but is it normal when its glowing orange?
Old Jan 10, 2006 | 04:06 AM
BadLuckAudi's Avatar
yes its normal for it to glow esp if your gettin on it, i came home the other day just from around town and i only got on it a little and the turbo was pretty red and at night its really red
Old Jan 10, 2006 | 12:46 PM
gregp1962's Avatar
If it's not boosting, it wouldn't be getting as hot would it? Will it be glowing if it's not boosting?
But, the original question... How do I know if the turbo is bad, or something else like the N75 or wastegate?
Old Jan 10, 2006 | 12:58 PM
clconversion's Avatar
I would check for a boost leak first its cheap and its pretty simple also with you cat being plugged this will also cause a loose of power so get that fixed first
Old Jan 10, 2006 | 03:01 PM
gregp1962's Avatar
Well, my gauge seems to read vacuum fine. It is very reactive when revving the engine in neutral and when "accelerating" in gear. It won't indicate even a little bit of boost. It seems to me that if there were a boost leak, I would see a little bit of boost and the vacuum would not be very reactive. BTW, it ldles fine.
Where are possible boost leaks? Could the N75 be malfunctioning?
Old Jan 10, 2006 | 05:47 PM
gregp1962's Avatar
OK, This is weird. I disconnected the battery last night as well as the connector on the throttle body. Then this monring, I reconnected it all and the car is running fine, turbo included. What is up with this car?
03a418tnate
Aug 10, 2010 08:07 PM
mr V8
18
Jun 23, 2006 03:21 AM
DickM
12
Mar 21, 2006 05:15 AM
